OOB connects but, screen scrolls
Apr 8th, 2009
I have a router in Montevideo that I need to replace, but before I do this I must get the OOB connection working. The modem answers and I see my login prompt, but the screen then scrolls and I cannot type my login info (its almost like someone is holding down return key). Could this be caused by echo on the line? I suppose I will get the local folks to have the dial line looked at. I was hoping someone might have some other suggestions. The router is a 2620XM and the modem is connected to the console port.
hadbou Tue, 04/14/2009 - 06:28
  • Bronze, 100 points or more
While connecting, modem is asking login prompts but the screen starts to scroll. For this problem Reset your modem then it will work fine.
