WCS 5.2.130 Access Point Up/Down Percentage report.
Apr 8th, 2009
I am trying to generate a management report to give me the AP disassociation/association statistics as a pecentage per group or floor map from our WCS. Is anyway of doing this as I find that the in built repoting templates do not allow for this. When we use a Airwave MS we are able to get this information OK. Any help here would be appreciated!
angreaves Tue, 04/14/2009 - 08:05
Hi Mary,
Thanks for your reply! When I look at the WCS V5.2 Configuration guide URL you posted. It shows me a menu option which does not appear on my WCS under the Reports> Client Reports> as shown in the document. We are running Ver so why can't we see some of the reports?
I have attached a screen dump of My WCS page, which shows no client association menu option listed under Reports.
Trending Topics - Security & Network
