STP port disable
kraptor123
Is it possible to keep a particular port (access or trunk) out of the spanning tree even though STP is enabled on the VLAN that the port belongs to? If so, how?
I would like to have no control protocols enabled on a particular NNI, and I can do this on other non-cisco switches.
Jon Marshall
You can effectively disable STP for a port if you use the "spanning-tree bpdufilter.." command - see attached link
http://www.cisco.com/en/US/docs/ios/lanswitch/command/reference/lsw_s2.html#wp1014574
Jon
7 Replies 7
Tshi M
Level 5
Level 5
when an access port is configured with span portf, that port no longer participate in the STP.
rgds,
That is incorrect , spantree portfast does not turn off spanning tree it just eliminates a couple of the spanning tree states so the port comes active faster, spanning tree is still running on that port...
viyuan700
Level 5
Level 5
On access port if you define portfast & bpduguard.
Port will be disabled if it gets BPDU means tries to take part in STP.
Jon Marshall
Jon
The spanning-tree bpdufilter seemed the best option to me, because the port never actually gets to the disabled/blocked state. Thanks for your help.
Here are some details I found on a different site -
The "spanning-tree bpdufilter enable" command on an interface is approximately equivalent to disabling the spanning tree for an interface.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/command/reference/S1.html#wp1179280
BPDU filtering allows you to prevent a port from sending and receiving BPDUs. The configuration is applicable to the whole interface, whether it is trunking or not. This command has three states:
•spanning-tree bpdufilter enable-This state unconditionally enables the BPDU filter feature on the interface.
•spanning-tree bpdufilter disable-This state unconditionally disables the BPDU filter feature on the interface.
•no spanning-tree bpdufilter-This state enables the BPDU filter feature on the interface if the interface is in operational PortFast state and if the spanning-tree portfast bpdufilter default command is configured.
Thanks for getting back to the board with that extra information.
Rated...
Victor
no spanning-tree vlan X
will turn off STP for the vlan
