FM/DM install problem
richclaxton
I have installed FM server 3.2(2c) with oracle database and it completed successfully.After the installation when i try to install FM client by browsing to FM server i get the login prompt for Web Client,after keying the credentials the page goes blank,can't see the link to install FM/DM.
I can install DM from a switch but how do i get FM ?
wdrootz
Level 4
Level 4
What switch are you using?
Switches are 9513's
The problem was due to Java not getting a connection to the localhost. Re-installed Java and problem went away.
Yes,
Most of the time it is possible due to Jave Runtime 1.5
Before reinstarting, it is worth trying the unconditional browser refresh (Ctrl+F5)
Hope this will help you..
