plz help with my asa 5510
Apr 8th, 2009
i work in jordan as a system admin in the ministry of environment and till recently i was depending on isa2006 and it works just fine , but we have a 5510 asa firewall device which was bought a few years ago but they couldnt work it proberly recently i decided to inhance the security level to use 2 fire wall design and decided to reuse the 5510 but the device was bought long time befor i came to the ministry i tryed to reconfigure it but couldnt connect to it throw the mgmt port so i tryed to reset it using the back buttom but it didnt i work my question is how can i reset this device manually or is there a way to log into the its gui plz help
