Fax Machine on Cisco Router 2821
Apr 8th, 2009
I have cisco 2821 with
WIC-2T
EVM-HD-8FXS/DID High density voice/fax extension module with 8FXS/DID
EM-HDA-3FXS/4FXO 7-port voice/fax expansion module-3FXS/4FXO
Obviously Fax will be connect with FXS port and Nortel PBX will connect with FXO and Leased line I will use to connect with remote Central Site CCM.
I have one confusion how my fax machine send fax to outside world.
Please help me out. What will be the configuration on Router.
Dennis Mink Thu, 04/09/2009 - 16:07
  • Blue, 1500 points or more
just create a 0T pattern voip dial peer on your gateway and point it to your leased line voice-port 0/x/0:14.
the only drawback of that is, is that your ccm is not aware of it. unless you use MGCP or a direct route pattern to the gateway from you call manager to the gateway
