longer prefix vs connected routes under EIGRP
Apr 8th, 2009
R1 has connected route
R2 has static route of
ip route next hop
R1 R2 run EIGRP, R2 redistribute the static route to EIGRP
the question is
is the R1 will learn the and install on the routing table or reject it?
Overall Rating: 5 (1 ratings)
lamav Wed, 04/08/2009 - 08:39
Yes, R1 should place the /32 route in the routing table. Although it is learned from a source with a greater AD than its directly connected route, it is not comparable. The 2 routes are not comparable because they have different length prefixes. The longer prefix always wins, regardless of AD.
