04-08-2009 09:17 AM - edited 03-04-2019 04:17 AM
Hi everyone,
I had inproper commands configured on a cable card interface.
cable arp filter request-send
cable arp filter reply-accept
I did a:
no cable arp filter request-send
no cable arp filter reply-accept
Unforunately, the interface shows "no cable arp filter request-send and no cable arp filter reply-accept"
The only way to remove the above lines is to reload the box. I still have problems with the device with those no cable arp commands in the running config and the only way to resolve the issue is to have them removed completely from the interface config. I cannot reload the box at this time.
What methods can be used to remove those "no" commands from the running config?
04-08-2009 09:20 AM
Try:
default cable arp filter request-send
default cable arp filter reply-accept
HTH,
John
04-08-2009 09:32 AM
Hi J,
I tried those commands, it configures the interface with the below:
cable arp filter request-send 3 2
cable arp filter reply-accept 3 2
I need to fully remove the cable arp filter commands from the interface. It can't be viewable when I do a show run on the cable interface.
Any other suggestions?
04-08-2009 09:36 AM
If running default gives you those lines, then those are the defaults. If you're putting "no" in front of it, then it would be disabled. Why can it not be viewed through your running config?
