Http URL/path rewrite
mferrando
I have the need to use the URL rewrite feature (convert from a http to https).
Our goal is to convert a specific http response that include a path to the same but using https protocol.
server response is : http://portal.pippo.com/guest/login
I want that ACE send the following:
https://portal.pippo.com/guest/login.
(ACE is doing SSL offload)
Only this page or all the /guest path need to be secured with SSL, all the other pages under portal.pippo.com must remain http.
I konw tha manual says that URL rewrite is applicable only to pure URL (without path).
Do you have any suggestion to implement this ?
Many thanks in advance.
Maurizio
2 Accepted Solutions
sachinga.hcl
Level 4
Level 4
Hi MAURIZIO,
You have to create A Layer 7 HTTP server load-balancing class map contains match criteria that classifies specific Layer 7 network traffic. You create a Layer 7 server load-balancing class map based on HTTP cookies, HTTP headers, HTTP URLs, protocol header fields, or source IP addresses.
he Layer 7 HTTP server load balancing has Regular expression matching against the received packet data from a particular connection based on the HTTP URL string.
Before doing this you have to create a classmap of layer3/4 in which you can nest layer 7 classmap.
Layer 7 Load-Balancing Example
•Load balances traffic to the SPORTS-SERVER and NEWS-SERVER server farms based on the following criteria:
-HTTP header and header value expression
-URL expression
•Classifies the 3-tuple flow of the VIP address, protocol, and port as matching criteria for server load balancing
•Utilizes an HTTP parameter map to enable HTTP persistence
Perform the following steps:
Step 1 Create a Layer 7 class map that defines an HTTP header and header value expression string and URL expression for load balancing to the SPORTS-SERVER server farm.
host1/Admin(config)# class-map type http loadbalance match-all
SPORTS-MAP_CLASS
host1/Admin(config-cmap-http-lb)# match http header host header-value
.*test.com
host1/Admin(config-cmap-http-lb)# match http url /sports/
host1/Admin(config-cmap-http-lb)# exit
Step 2 Create a Layer 7 class map that defines a URL expression for load balancing to the NEWS-SERVER serverfarm.
host1/Admin(config)# class-map type http loadbalance NEWS-MAP_CLASS
host1/Admin(config-cmap-http-lb)# match http url /news/
Step 3 Create a Layer 7 server load-balancing policy by entering the following commands:
host1/Admin(config)# policy-map type loadbalance first-match
L7_SLB_POLICY
host1/Admin(config-pmap-lb)# class SPORTS-MAP_CLASS
host1/Admin(config-pmap-lb-c)# serverfarm SPORTS-SERVER
host1/Admin(config-pmap-lb-c)# exit
host1/Admin(config-pmap-lb)# class NEWS-MAP_CLASS
host1/Admin(config-pmap-lb-c)# serverfarm NEWS-SERVER
host1/Admin(config-pmap-lb)# class class-default
host1/Admin(config-pmap-lb-c)# serverfarm SERVER-HANDLE-ALL
host1/Admin(config-pmap-lb)# exit
Step 4 Create a Layer 3 and Layer 4 class map that classifies the 3-tuple flow of the VIP address, protocol, and port as matching criteria for server load balancing by entering the following commands:
host1/Admin(config)# class-map L4_SLBVIP_CLASS
host1/Admin(config-cmap)# match virtual-address 192.168.5.10 tcp port
eq 80
host1/Admin(config-cmap)# exit
Step 5 Create an HTTP parameter map to enable HTTP persistence by entering the following commands:
host1/Admin(config)# parameter-map type http HTTP_PARAMETER_MAP
host1/Admin(config-parammap-http)# persistent-rebalance
host1/Admin(config-parammap-http)# exit
Step 6 Create a Layer 3 and Layer 4 policy map to activate the traffic classifications outlined in the previous steps by entering the following commands:
host1/Admin(config)# policy-map multi-match L4_SLB_POLICY
host1/Admin(config-pmap)# class L4_SLBVIP_CLASS
host1/Admin(config-pmap-c)# loadbalance policy L7_SLB_POLICY
host1/Admin(config-pmap-c)# loadbalance vip inservice
host1/Admin(config-pmap-c)# appl-parameter http advanced-options
HTTP_PARAMETER_MAP
host1/Admin(config-pmap-c)# exit
host1/Admin(config-pmap)# exit
Step 7 Apply the completed policies to interface VLAN 10 by entering the following commands:
host1/Admin(config)# interface VLAN 10
host1/Admin(config-if)# service-policy input L4_SLB_POLICY
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/administration/guide/mapolcy.html#wp1256712
Use the ssl url rewrite location command. SSL URL rewrite changes the redirect URL from http:// to https:// in the Location response header from the server before sending the response to the client. By doing so, it allows you to avoid nonsecure HTTP redirects because all client connections to the web server will be SSL, thus ensuring the secure delivery of HTTPS content back to the client. Use the no form of this command to remove the SSL rewrite specification from the configuration.
ssl url rewrite location expression [sslport number1] [clearport number2]
no ssl url rewrite location expression [sslport number1] [clearport number2]
Usage Guidelines
After you create an action list and configure an HTTP redirect URL for SSL, you must associate the action list with a Layer 3 and Layer 4 policy map. For details, see the Cisco Application Control Engine Module Server Load-Balancing Configuration Guide.
Examples
To specify SSL URL rewrite using the default SSL port of 443 and clear port of 80, enter:
host1/Admin(config)# action-list type modify http HTTP_MODIFY_ACTLIST
host1/Admin(config-actlist-modify)# ssl url rewrite location www.website.com
In this case, the ACE rewrites all HTTP redirects to http://www.website.com/ as https://www.website.com/ and forwards them to the client.
Use the following URL :
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/command/reference/actnlist.html#wpxref82197
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/command/reference/actnlist.html#wp1041777
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
sachin
sachinga.hcl
Level 4
Level 4
Hi MAURIZIO,
-URL expression
SPORTS-MAP_CLASS
.*test.com
L7_SLB_POLICY
eq 80
HTTP_PARAMETER_MAP
Usage Guidelines
Examples
sachin
Sachim, I implemented the solution:
I configured a L7 class map to intercept the specific page and used a serverfarm redirect to get the client to use the https instead the http.
The ssl url rewrite is used only during http redirect message coming from the server for SSL session terminated on ACE.
For requests coming as normal http, it does not work (no action takes place).
Thanks for your help.
Regards, Maurizio
