syslog collector status all zeros
Apr 8th, 2009
I'm running RME 4.0.6 and used to get notifications via Automated Actions for specific facilities/keywords but those haven't come in a while. I checked the Syslog Collector Status and all columns have a zero count. This doesn't seem normal but hey I could be wrong....
thanks
js
Joe Clarke Wed, 04/08/2009 - 15:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Is this on Windows or Solaris?
Joe Clarke Wed, 04/08/2009 - 16:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Check the syslog.log to see if new messages are arriving in this file. Make sure the crmlog service is running, and bound to UDP port 514.
js88888888 Wed, 04/08/2009 - 16:28
The syslog service is running. However, the syslog.log file shows it is 4.3GB and was last modified on 3/12/09. I can't open it due to its size. Would this be the problem? Plenty of CPU and memory available.
Joe Clarke Wed, 04/08/2009 - 16:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You should consider zeroing it out. Stop the crmlog service, then run:
pdterm SyslogCollector SyslogAnalyzer
Then run:
logrot_trunc NMSROOT\log\syslog.log
That will zero out the file. Then restart the crmlog service, and run:
pdexec SyslogCollector SyslogAnalyzer
Then watch the file to see that new messages arrive. If they do, the syslog counts should increment.
js88888888 Wed, 04/15/2009 - 08:43
Thanks much, this did the trick. Can this be scheduled via Ciscoworks or RME? Or somehow automatically managed?
Joe Clarke Wed, 04/15/2009 - 08:47
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can configure logrot.pl to do this automatically. Consult the Common Services online help for more details on configuring logrot. Just search for "logrot". Once you have it configured, you can schedule it with the Windows AT command.
