ASA 5510 snmp tunnel L2L
Apr 8th, 2009
Hello
There are some OIDs
- which monitor tunnel L2L, phase 1&2
- which monitor quantity of logged road warriors in remote access mode ? or quantity of tunnels L2L
thank You for help
merabtavart Fri, 07/22/2011 - 01:45
Check
http://www.vpnttg.com/
Advantage   of VPNTTG over other SNMP based monitoring software’s is  following:   Other (commonly used) software’s are working with static OID  numbers,   i.e. whenever tunnel disconnects and reconnects, it gets  assigned a  new  OID number. This means that the historical data, gathered  on the   connection, is lost each time. However, VPNTTG works with VPN  peer’s  IP  address and it stores for each VPN tunnel historical  monitoring  data  into the SQL server and into the RRD (Round Robin  Database) file.
