Single Public PAT to multiple Internal
Answered Question
Apr 8th, 2009
ASA 5510
Need to NAT single public IP to multiple internal IPs.
Outside:1.1.1.1/25 -> DMZ:192.168.1.10/25
while...
Outside:1.1.1.1/443 -> Inside:192.168.2.10/443
and
Outside:1.1.1.1/1352 -> Inside:192.168.2.10/1352
Initially tried (via ASDM) static P/NAT from DMZ to Outside using Port Address Translation with port 25 both in and out.
Then adding static P/NAT from Inside to Outside using Port Address Translation for port 443.
Problem arises when I want to specify the third static P/NAT for port 1352, or when I leave PAT on for DMZ host, but turn it off for the Inside host.
The ultimate goal is for port 25 on the public IP to go to the DMZ host while 443 and 1352 get sent to the Inside host.
How can I accomplish this? It's OK to say the ASDM won't let you do this, but I won't be so happy to hear that the ASA cannot accomplish this knowing that there are a bunch of half-assed appliances out there that DO handle this.
Thanks for helpin me out yet again!
Correct Answer by roshan.maskey about 7 years 10 months ago
Cisco ASA does support that. Please try from CLI.
static(dmz,outside) tcp 1.1.1.1 25 192.168.1.1 25
static(inside,outside) tcp 1.1.1.1 443 192.168.2.1 443
static(inside,outside) tcp 1.1.1.1 1352 192.168.2.1 1352
Also add these access-list in outside interface access-list.
access-list outside_in extended permit tcp any host 1.1.1.1 eq smtp
access-list outside_in extended permit tcp any host 1.1.1.1 eq https
access-list outside_in extended permit tcp any host 1.1.1.1 1352
Overall Rating: 5 (1 ratings)
Correct Answer
roshan.maskey Wed, 04/08/2009 - 17:06
bsisco Thu, 04/09/2009 - 09:08
I should've known that even though the GUI ASDM complained about it and even though the CLI (via the GUI) complains about it but let's it go that it was possible.
Spoiled by yet another GUI.
Thanks Roshan
