Drag and Drop Fails
spollock
Moved to a different machine and logged in w/CCA.
Tried dragging RingList1.xml to the UC500 and it says something about validating the file and then"this file is not allowed to be uploaded to this device"
If have done this from the original machine that I installed it with, worked fine.
Both machines are are/were on the internal network of the UC500 192.168.10.x
Plenty of space on the flash, I find nothing in the settings related.
ideas?
9 Replies 9
Steven Smith
Level 7
Level 7
What version of CCA are you using?  Can you attach the CCA logs from when it fails?
It sez CCA 1.9(1)
I see nothing in the event notification or system messages related to this.
On the device itself, I see nothing as well.
Cowacella#show log
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 480 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
        Logging to: vty4(0)
    Buffer logging:  level debugging, 480 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 757 message lines logged
Log Buffer (4096 bytes):
00)msecs, more than (2000)msecs (227/8),process = Skinny MOH Server.
-Traceback= 0x80023CFC 0x802D23FC 0x802D2548 0x802D454C 0x802AF454 0x802C15A8 0x
802BB5DC 0x802BBAEC 0x802BBC34 0x802B1D54 0x802AE8A8 0x8125F20C 0x805F56C4 0x805
FA930 0x80172938 0x80175204
000461: Apr 15 23:53:57.976: %SYS-3-CPUHOG: Task is running for (56000)msecs, mo
-Traceback= 0x80023CEC 0x802D23FC 0x802D2548 0x802D454C 0x802AF454 0x802C15A8 0x
000462: Apr 15 23:53:59.976: %SYS-3-CPUHOG: Task is running for (58000)msecs, mo
phershaw
It looks like CCA1.9.1 restricts the drag & drop feature to IOS files only ?
I'm sure previous versions allowed any file type.
Phil
According to the BU and some information I recently asked (good question about drag and drop), I was told the following is supported in CCA 1.9.1...
TFTP is used for:
.AU, .WAV, .BIN and .TAR (only for CP-500 language files)
IOS Image and copying the Phoneload and Support-Files tar files.
CUCME language files (localization)
factory default configuration
system speedial.xml file
FTP is used for
CUE upgrade
CUE language files (localization)
backup/restore of CUE config and data files
AA script & prompt uploading
None of those seem to allow for my own .xml files.  I was hoping to jump start some apps from the local flash.
I guess someone thinks that is a bad idea.
tx
-Steve
Couple of more things I noticed.
There is no ftp to the box.  ftp 192.168.10.1 fails as I would expect it to on a router.  I am also a 192.168.10.x address
I created a new .raw file and drag and drop fails with this in the same manner.
Not sure how I can get any files onto flash a this point other than to perhaps setup a remote tftp server.
IOS does have an FTP client. Do:
copy ftp://user:password@x.x.x.x   flash:
IOS cannot act as an FTP server though.
Hope this helps.
Marcos
Thanks Marcos, I forgot all about that.  I am an old Cisco guy...
I got this to work, but the only way was by loading up an FTP server on a PC and copying to flash.  Seems like we need a product enhancement to allow drag and drop to actually function.
-S
D&D should work, but only for certain file types.
Marcos
