Can the AP1310 running on IOS 12.3 supporting on LDAP
Apr 8th, 2009
hi,
My WLAN topology is like this: one WLSE for centralized management, LDAP server for authentication purpose, plus aironet AP1310.
I would like to ask either the AP1310 able to support the user authentication on LDAP server.
If yes, can please suggest what need to configure over the AP and the WLSE.
thanks in advance
noel
drolemc Tue, 04/14/2009 - 08:16
I feel the AP1310 running on IOS 12.3 cannot supporting on LDAP
gamccall Tue, 04/14/2009 - 09:22
No. You can configure local authentication on the 1300's, which will allow an AP to act as its own RADIUS server, but it will only authenticate against local user accounts on the AP, not an external LDAP server.
If you were running lightweight mode, the controllers can do "Local EAP" and authenticate to an LDAP, but that's not an option for IOS/autonomous APs.
If you must authenticate against the LDAP with your current deployment, your best option will be to set up a RADIUS server- ACS, IAS, FreeRadius, etc.
Note that there are issues that may come into play when attempting to authenticate using PEAP/MSCHAPv2 against an LDAP directory, so be careful if you're using 802.1X that your inner authentication method is compatible with the directory you're using.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
