memory problem
Apr 8th, 2009
Hi, I use Cisco 871 IOS ver. 12.4(24)T.
I have losed connectivity to internet, and when i look at the log buffer, i get these messages:
011510: .Apr 9 09:03:50.040 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 2789> from <cli 192.168.3.20>.
011511: .Apr 9 09:03:51.267 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 5786> from <cli 192.168.3.252>.
011512: .Apr 9 09:03:54.039 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 2789> from <cli 192.168.3.20>.
011513: .Apr 9 09:04:01.269 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 5786> from <cli 192.168.3.252>.
011514: .Apr 9 09:04:02.040 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 56292> from <cli 192.168.3.20>.
011515: .Apr 9 09:04:02.268 eest: %SYS-2-CHUNKEXPANDFAIL: Could not expand chunk pool for Firewall State. No memory available -Process= "Chunk Manager", ipl= 3, pid= 1, -Traceback= 0x8005763Cz 0x80393F6Cz 0x803973B8z
011516: .Apr 9 09:04:03.040 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 56292> from <cli 192.168.3.20>.
%SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x80058904, alignment 32
Pool: Processor Free: 2164336 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Syslog", ipl= 3, pid= 197, -Traceback= 0x800255FCz 0x8003F204z 0x80058908z 0x80057750z 0x8005ADFCz 0x800573A4z 0x81433250z 0x8144CB64z 0x81452AB0z 0x81D61CE8z 0x81D5A7B8z 0x81D5B228z 0x81D5F8D8z 0x81D5FF44z 0x80E8278Cz 0x80E842D0z
011522: .Apr 9 09:04:11.042 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 56292> from <cli 192.168.3.20>.
011523: .Apr 9 09:04:21.267 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 5786> from <cli 192.168.3.252>.
Pool: Processor Free: 2168932 Cause: Memory fragmentation
-Process= "Syslog", ipl= 3, pid= 197, -Traceback= 0x800255FCz 0x8003F204z 0x80058908z 0x80057750z 0x8005ADFCz 0x800573A4z 0x81433250z 0x8144CB64z 0x81452AB0z 0x81D62308z 0x81D74278z 0x81D68298z 0x81D65164z 0x81D5C1FCz 0x81D5F8D8z 0x81D5FF44z
011530: .Apr 9 09:04:39.466 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 6435> from <cli 192.168.3.3>.
011531: .Apr 9 09:04:43.465 eest: %DNSSERVER-3-UDPDNSOVERLOAD: Low available memory: dropping <id# 6435> from <cli 192.168.3.3>.
I assume that the memory has been overloading, but why this happend?
I reloaded the router and now works fine. Can anybody helps me ? Thanks in advance!
Paolo Bevilacqua Thu, 04/09/2009 - 00:03
  • Hall of Fame,
    Founding Member
This happens a lot with IOS, it's a class of bugs called "memory leak".
You best bet is to upgrade IOS and hope it has beed fixed.
zenon_electronics Thu, 04/09/2009 - 00:26
Hi p.bevilacqua, thanh you for your reply! I'm currently with the newest IOS :( Any other idea ?
Paolo Bevilacqua Thu, 04/09/2009 - 01:49
  • Hall of Fame,
    Founding Member
Downgrade IOS.
