Cisco BCMSN Command Reference: error?
Answered Question
Apr 9th, 2009
Hi networkers,
Does anybody have used that book? I think there's a typo in the "Configuration example: InterVLAN Communication" exercice, page 48.
If you take a look at it, L2Switch2 has 4 VLANs in the 172.16.x.0/24 network. But the workstations have IP addresses that belong to the 192.168.x.0 network.
Besides, subinterfaces on the CORP router have 192.168.x.0 network addresses.
Any idea?
Correct Answer by glen.grant about 8 years 1 month ago
Thats just a poor job of proofreaders checking the book , the addressing is wrong . they substituted 192.168 for the 172 addresses .
Overall Rating: 4 (1 ratings)
Jon Marshall Thu, 04/09/2009 - 01:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Wassim
I don't have that book but it wouldn't be the first time that there were errors. A lot of computer books have errors in the configuration examples. You may want to check the ciscopress site to see if there are any updates.
Perhaps if you posted the example. Not sure what you mean by L2 vlans in 172.16.x.0/24. If the workstations have 192.168.x.x addressing and the L2 switch connects to the router via a trunk and the subinterfaces on the router have 192.168.x.x then where does the 172,16.x.x part come in ?
Jon
Correct Answer
glen.grant Thu, 04/09/2009 - 03:25
  • Purple, 4500 points or more
Giuseppe Larosa Thu, 04/09/2009 - 04:39
  • Hall of Fame,
    Founding Member
Hello Wassim,
I have another edition of the book.
However, be prepared because some errors are present in every book so a critical indipendent point of view has to be used.
It may be possible in a first time L2switch2 was connected to L3switch1 instead of CORP router in the idea of the example designer.
Hope to help
Giuseppe
