VPN group membership
Apr 9th, 2009
Can someone advise on how to lock a vpn profile from a vpn concentrator to specific group membership with ACS. I have multiple groups and profiles and they allow access to one another. This is so I can use downloadable ACLs on the vpn session - which works fine.
John Blakley Mon, 04/13/2009 - 08:12
  • Purple, 4500 points or more
You'll need to use option class 25. For the value, use "OU=;". This will assign that user to the group. (The OU is case sensitive, and you need the ";". Put all of it in without quotes.)
HTH,
John
