Site-Site VPN Problem
Morning all,
I wonder if anyone has seen this problem before and knows what the issue is:
I've set up an site-site VPN between a 6503 and a 2600 internally, to mock what's going to happen when the 6503's move to a seperate site.
The tunnel comes up ok and I can ping the far end networks no problem (and vise versa). The problem comes if I try to telnet, ssh or basically use the
far networks in any way. Say for example I try to telnet to a switch there, the port seems to open but nothing happens (if I do it from DOS I get the blank
black screen showing the port is open). Same for SSH to a linux machine on one of the far networks.
The ports appear to open but I get no login prompts or anything. I can see the packets coming and going so it's really strange.
Have I just missed something really basic that you'll tell me in about 5mins or is this a deeper problem?
srue Thu, 04/09/2009 - 09:27
are you getting bidirectional tunneled traffic?
sh cry ipsec sa
..and see if the encrypt/decrypt counters are increasing on both sides.
have you tried something other than this management traffic to test it? http? https? icmp? etc.
