IOS Image Selection help
Apr 9th, 2009
I have 1800 series router. I need some assistance to download the IOS image from the Cisco website. Under download we have the option 1811 and 1812 Integrated Service router. Which image should I select? Is it under 1811 or 1812? Shoe version output is given below.
RTR#show version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(11)T2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 30-Apr-07 14:36 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH8, RELEASE SOFTWARE (fc2)
RTR uptime is 21 hours, 3 minutes
System returned to ROM by reload at 22:21:31 JST Wed Apr 8 2009
System image file is "flash:c181x-advipservicesk9-mz.124-11.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1812-J (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FHK110918RZ, with hardware revision 0000
10 FastEthernet interfaces
1 ISDN Basic Rate interface
31488K bytes of ATA CompactFlash (Read/Write)
Overall Rating: 4 (1 ratings)
m.sir Thu, 04/09/2009 - 06:05
  • Gold, 750 points or more
In your output you can see Cisco 1812-J (MPC8500) processor .. So I would go for 1812
and also all 1800s have ISDN BRI dial backup, except the 1811, which uses V.92 analog modem dial backup instead
and
your output saying it has 1 ISDN BRI so its 1812
avilt Thu, 04/09/2009 - 20:31
I downloaded the latest image which is of 23MB in size. My routers flash size is 32MB
and I cannot upload the image thru Cisco Network Assistant. It says the image cannot be uploaded even with the current image deletion. How do I proceed?
t-yamashita Thu, 04/09/2009 - 22:16
Hi, Avil
Can you use TFTP instead of Cisco Network Assistant?
Tomoyuki
