PCI_FIND_FAILURE:
Apr 9th, 2009
Can you helm me to resolve this trouble.
My switch reboting and writing:
Booting after a softreset ...
C2950 Boot Loader (C2950-HBOOT-M) Version 12.1(11r)EA1, RELEASE SOFTWARE (fc1)
Compiled Mon 22-Jul-02 17:18 by antonino
WS-C2950G-48-EI starting...
Base ethernet MAC Address: 00:0b:fd:4a:b7:00
Xmodem file system is available.
Initializing Flash...
flashfs[0]: 1 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 3133440
flashfs[0]: Bytes available: 4608000
flashfs[0]: flashfs fsck took 5 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
Loading "flash:/c2950-i6q4l2-mz.121-22.EA12.bin"...###########################################################################################################################################################################################################
File "flash:/c2950-i6q4l2-mz.121-22.EA12.bin" uncompressed and installed, entry point: 0x80010000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA12, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 07-Jul-08 23:39 by amvarma
Image text-base: 0x80010000, data-base: 0x80570000
Initializing flashfs...
flashfs[1]: 1 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 3133440
flashfs[1]: Bytes available: 4608000
flashfs[1]: flashfs fsck took 6 seconds.
flashfs[1]: Initialization complete.
Done initializing flashfs.
POST: System Board Test : Passed
POST Failure: Ethernet Controller Test: Failed
=== Flushing messages (00:00:08 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
00:00:08: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:08: %PLATFORM_HW-3-PCI_FIND_FAILURE:
The number of asics expected were 2, PCI bus scan found -1
00:00:08: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Signal 10, Exception code (0x0008)!
Frame 00: SP = 0x80BA7880 PC = 0x800F87D4
Frame 01: SP = 0x80BA78A0 PC = 0x800F8AA8
Frame 02: SP = 0x80BA7980 PC = 0x800F94C4
Frame 03: SP = 0x80BA79B8 PC = 0x801DA220
Frame 04: SP = 0x80BA79D0 PC = 0x801DA2C4
Frame 05: SP = 0x80BA79F8 PC = 0x80120494
Frame 06: SP = 0x80BA7A30 PC = 0x80120690
Frame 07: SP = 0x80BA7B40 PC = 0x801BE90C
Frame 08: SP = 0x80BA7B58 PC = 0x801BE8F8
=== Crash Fault History ===
Signal = 10, Code = 0x8, Uptime 00:00:08
r0: 00000000, AT: 00000000, v0: 00000000, v1: 80860000
a0: 00000030, a1: 00000000, a2: 00000000, a3: 00000001
t0: 00000038, t1: 1000E701, t2: 10000000, t3: FFFF00FF
t4: 802D58B0, t5: A08D2ABC, t6: A08D2AB8, t7: A08D2AB4
s0: 80C0222C, s1: 00000002, s2: 80BD006C, s3: 00000001
s4: 80BA78F8, s5: 80BA7938, s6: 80BA78F0, s7: 805D0000
t8: A08D2B10, t9: 00000000, k0: 00000000, k1: 00000000
gp: 807E7700, sp: 80BA7880, s8: 805D0000, ra: 800F87D0
EPC: 800F87D4, ErrEPC: FFE7F9BF, BadVA: 0x00000030, SREG: 1000E703
Cause: 0x00000008 (code 2): TLB (load or ifetch) exception
-Traceback= 800F87D4 800F8AA8 800F94C4 801DA220 801DA2C4 80120494 80120690 801BE90C 801BE8F8
greg.washburn Thu, 04/09/2009 - 04:16
I remember the 2950s having a similar error with older versions of IOS but not with the code release you are using.
To me it seems you will need to look for a replacement switch.
Leo Laohoo Thu, 04/09/2009 - 18:11
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Unfortunately, "POST Failure: Ethernet Controller Test: Failed" means that you have a hardware PCI chip failure.
