How to update the CF card from 64M to 254M?????????????
Apr 9th, 2009
I have 2 6509, each one with 2 sup720-3b, and each sup720-3b has a 64M CF card in disk0.
Now I want to change these 4*64M CF card to 512M CF card. I have only very shortly time to do it, pls kindly give me a good procedure. I also need the detail commands. THanks
Overall Rating: 3 (2 ratings)
Leo Laohoo Thu, 04/09/2009 - 18:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
1. Don't forget to FORMAT your new CF before you put any files into it.
2. Don't even think about the USB. USB is NOT SUPPORTED on the Sup32/Sup720 cards.
Happy Easter!
zhangjianping Thu, 04/09/2009 - 18:52
Thanks.
But not enough.
You know, each 6509 has 2 sup720-3b and 2 CF card. I wanna know how to copy the date from the old flash to these 2 new card, shall I plug out one of the SUP720-3b and then plug out another one?
Leo Laohoo Thu, 04/09/2009 - 19:06
  • Hall of Fame,
    2017 LAN, Wireless
"You know, each 6509 has 2 sup720-3b and 2 CF card" < --- You mean 2 EXTERNAL SLOTS and 1 INTERNAL slot. Whether you put 2 CF into your Sup720 is something no one can tell.
"But not enough." < --- I have no idea what you mean by this and I don't even want to find out. :)
Leo Laohoo Thu, 04/09/2009 - 19:08
  • Hall of Fame,
    2017 LAN, Wireless
"copy the DATE from the old flash to these 2 new card" < --- Hooooooo boy! I hope I completely misunderstood you.
If you want to copy the ENTIRE CONTENTS from your sup-bootdisk: to your sup-bootflash0: and/or sup-bootflash1:, then use the command "copy sup-bootdisk:* sup-bootflash0:".
If you want to copy all contents from external flash 1 to external flash 2, then use the command "copy sup-bootflash0:* sup-bootflash1:".
Does this help you?
