Nagios Voice Alerts
Apr 9th, 2009
Hi all, I hope you can help me out here or point me in the right direction.
I'm running CCME 4.1 along with unity express 2.1 and I use Nagios to monitor my servers, Routers and Switches.
What I would like to do is set-up Nagios so its escalation send me a text on the first alert which I have done but on a second alert I would like for my CCME to call me and play a pre-recorded message to me, not sure if that would be CCME or Unity, I think I heard it called call hand off.
Not sure if this can be done with what I have, do any of you know if it can?
My current Installed Packages:
- Installer 2.1.3
- Bootloader (Primary) 2.1.2
- Infrastructure 2.1.3
- Global 2.1.3
- GPL Infrastructure 2.1.3
- Voice Mail 2.1.3
- Bootloader (Secondary) 2.1.2
- Core 2.1.3
- Auto Attendant 2.1.3
ebreniz Wed, 04/15/2009 - 09:26
To enable this trap, you need to enable ccmPhoneStatusUpdateAlarmInterval and ccmPhoneFailedAlarmInterval each. These values only are enabled via snmp set command such like net-snmp or tools in openview.
ccmPhoneFailedAlarmInterval OBJECT-TYPE
SYNTAX Integer32 (0 | 30..3600)
UNITS "seconds"
MAX-ACCESS read-write
STATUS current
"The minimum interval between sending of the ccmPhoneFailed
notification in seconds. The ccmPhoneFailed notification is
only sent when there is at least one entry in the
ccmPhoneFailedTable and the notification has not been sent
for the last ccmPhoneFailedAlarmInterval defined in this
object. A value of 0 indicates that the alarm notification
is disabled."
DEFVAL { 0 }
::= { ccmAlarmConfigInfo 2 }
