ACE shared vlans
Answered Question
Apr 9th, 2009
Hello
we have a pair of ace with 2 differnt context.
The goal is to route traffic from one context (a) to the other one (b)
Therefore we create a shared vlan between the contexts.
The Problem is that it is not possible to Ping the other Context (or get traffic over it).
In the arp table the mac address of the other context is not learned (just 0)
In the admin context we did alread configured the shared vlan host id to avoid mac adress problems.
It is only working if one of the context is hot in the maschine a and the other one is hot on maschine b. Then it works as expexted.
Config:
General:
access-list ACL_ANY line 8 extended permit ip any any
policy-map multi-match POL_TCP
class class-default
connection advanced-options PMAP_TCP
parameter-map type connection PMAP_TCP
no random-sequence-number
policy-map type management first-match POL_ICMP
class CLASS_ICMP
permit
class-map type management match-any CLASS_ICMP
2 match protocol icmp any
Context A:
interface vlan 827
ip address 10.208.64.42 255.255.255.248
alias 10.208.64.41 255.255.255.248
peer ip address 10.208.64.43 255.255.255.248
no normalization
no icmp-guard
access-group input ACL_ANY
access-group output ACL_ANY
service-policy input POL_ICMP
service-policy input POL_TCP
no shutdown
Context B:
interface vlan 827
description PEP_5.0_Linknetz_to_GGSN_Context
ip address 10.208.64.44 255.255.255.248
alias 10.208.64.46 255.255.255.248
peer ip address 10.208.64.45 255.255.255.248
no normalization
no icmp-guard
mac-sticky enable
no shutdown
Admin Context:
To avoid duplicate Mac's
shared-vlan-hostid 1
peer shared-vlan-hostid 2
Correct Answer by dario.didio about 8 years 3 weeks ago
Hi, it is not possible to do this.
A quote from the Routing-Briding configuration guide:
"The ACE also supports shared VLANs, which are multiple interfaces in different contexts on the same VLAN within the same subnet. Only routed interfaces can share VLANs. Note that there is no routing across contexts even when shared VLANs are configured."
link: http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/rtg_brdg/guide/vlansif.html#wp1004100
You need a device outside the ACE to accomplish this.
HTH,
Dario
Overall Rating: 4 (1 ratings)
Correct Answer
dario.didio Thu, 04/09/2009 - 05:47
  • Silver, 250 points or more
HTH,
Dario
sachinga.hcl Sat, 04/11/2009 - 20:03
Hi Dear,
There is no routing possible across contexts even when shared VLANs are configured.
The ACE appliance has four physical Ethernet interface ports. All VLANs are allocated to the physical ports. After the VLANs are assigned, you can configure the corresponding VLAN interfaces as either routed or bridged for use. When you configure an IP address on an interface, the ACE appliance automatically makes it a routed mode interface.
Similarly, when you configure a bridge group on an interface VLAN, the ACE appliance automatically makes it a bridged interface. Then, you associate a bridge-group virtual interface (BVI) with the bridge group.
The ACE appliance also supports shared VLANs; multiple interfaces in different contexts on the same VLAN within the same subnet. Only routed interfaces can share VLANs.
n routed mode, the ACE is considered a router hop in the network. In the Admin or user contexts, the ACE supports static routes only. The ACE supports up to eight equal cost routes for load balancing.
You need a router outside the ACE ting betweeen thse two context.
kind regards,
sachin
