CUPC unable to do desk phone control
Apr 9th, 2009
We run CUPS 7.0 and CUPC 7.0 with CUCM 6.1.3.
I have set up an number of users with CUPC and they are abel to choose desk phone from CUPC.
Some users that I have added can only use the softphone, although I have:
-assigned the users as CUP users
-assigned desk phone control
-assigned a CTI gateway profile.
-associated the line on the deskphone with the appropriate user ID (CUCM)
-associated both the desk phone device and CUPC device to the end user configuration in CUCM
-added the end user to CCM end user and CTI enable group
-checked Allow CTI control of device settings at the end user and extension config, both boxes ticked
-checked the presence viewer for the failing user, and see all the settings correct.
I suspect there is something wrong with CTI control of the desk phone from CUPC, but cannot seem to find any configuration differences between the users that fail and those that have desk phone control.
I
I have compared
Overall Rating: 5 (2 ratings)
Dennis Mink Thu, 04/09/2009 - 15:00
Yes CUPS is using LDAP for authentication,
using the defualt port, 389 (off the top of my head)
htluo Thu, 04/09/2009 - 17:12
change the port to 3268 and restart CTIManager.
Michael
Tommer Catlin Fri, 04/10/2009 - 12:52
are you sure your CUPC client can "talk" to the callmanager server? Basically, if you look at the Server Health on the CUPC client, and see the Deskphone retrying, take a look at the server name. If the server name can not be resolved from the client to the servers, you need to resolve this first. On the CUPS server, ping the callmanager hostname.
on the CUPC client computer, ping the cucm hostname. If needed, put a host file on teh CUPC file for testing. It is possible, even though you setup IP address for CUCM, it's still using the hostname.
(and whatever Michael says!)
stuart-bapple Mon, 04/13/2009 - 12:35
Just install 500 cupc clients and in the process I ran into a few issues that resulted in what you are experiancing:
here goes:
in call manager
1. make sure user has licensing enaabled under capabilities assignment"no brainer but just in case"
2. build the cup phone and make sure the device name after upc does not exceed 12 charecters and all capitals letters
3. set device pool of cupc to be the same as hard phone
4.associate the owner user id to the user
5.associate the primary phone of the user
note, allow control of cti should not be checked here
6.associate digest user
save and click ok on pop-up
click add a new extension
enter directory number and route partiton
note, allow control of device from cti must be checked here
7. click associate end userbutton and chose user.
save
under user management
1. find or add the user under end user
click the device association button
find desk and cupc phone and associate.
save
click go to go back to users page
select the subscribe calling search space " recommended setting would be internal css
check the allow control of device from cti
select the correct "primary extension from the dropdown"
click the add to users button
find and check the standard cti enabled
click the add selected button
save
on the presence server under user settings
use drop down to select the following
prefeerred cti device
unity profile
meetingplace profile
device pool
ldap profile
sip proxy profile
save
couple of things
1. name for user must be the same as ldap
2. mac address of cti device in cupc must match the users
3. the 12 char name thing very important.
hope this helps.
Thanks Stuart and Michael. Perhaps you guys should write Cisco Documentation!
I'm still having the problem though. I am Using GC (port 3268) and have checked everthing else here I can find. Using CUCM 6.1.3.2000-1 (Pub and one Sub) and Single CUP 6.0.5.100.13. Integrated with AD and using AD authentication, Again using 3268. AD authentication works fine for CUCM. CUPC log shows :
WARN LCCallControl - (CCMSG_QBE_PROVIDEROPENFAILED) ProviderOpen failed: Directory login failed - timeout
Getting a bit desperate now! Any other things you can suggest?
Thanks.
[Michael your book is on it's way!]
htluo Wed, 04/22/2009 - 16:04
"ProviderOpen failed: Directory login failed - timeout" means CTIManager authentication with LDAP was timed out.
Could you go to "Cisco Unified Serviceability > Tools > Control Center - feature services" and see how long the "Cisco CTIManager" has being running? If it doesn't seem to be restarted lately, please restart it.
Usually, restart CTIManager (on all CUCM servers) would fix this problem.
If that didn't fix the problem, you may go to CUCM Admin > System > Service Parameters > Cisco CTI Manager > Advanced. Change "CTI Request Timer" from 5 to 300.
Please note:
1) You need to restart CTIManager after the change.
2) You have to do it for each CUCM server.
Michael
