Remove CCX 5 license
Answered Question
Apr 9th, 2009
Is there any way to remove installed licenses from CCX 5.0
Correct Answer by Chris Deren about 7 years 10 months ago
1 . Start the Config Object Browser.
Go to start -> run and type "cet"
(or run cet.bat in the "C:\Program Files\wfavvid" directory )
2 . Select "com.cisco.crs.cluster.config.LicenseConfig" from the config object type tree.
3 . Delete the rows for the LicenseConfig (You can see it on the right pane.)
4. Restart the node manager.
HTH, please rate all posts!
Chris
Overall Rating: 4.5 (4 ratings)
Correct Answer
Chris Deren Mon, 04/13/2009 - 06:35
Chris
