Warning message
CCX Verison AP1231 \ Intel Client 12.0.4.0
Apr 9th, 2009
How do I know that the Client I am using is compatible with the AP? The Intel Client is using CCX V4. We also have other clients that are at CCX V3. I am seeing some issues with Authentication using Leap wtih the Newest Intel Client.
At times the Client cannot authenticate even though there is signal. If I move to another AP I get authenticated.
jeff.kish Thu, 04/09/2009 - 07:25
  • Silver, 250 points or more
If you want to troubleshoot without CCX, you can perform the following config via CLI:
config t
interface Dot11Radio0
no dot11 extension aironet
CCX is backward-compatible, so you should have no problem running v3 and v4 clients at the same time. What version of code are you running on the AP? Maybe it's an old code that cannot support v4 clients. You could try upgrading your AP to the newest version of code and see if that helps.
ckowalchyk Thu, 04/09/2009 - 11:10
The code version is c1200-k9w7-mx.123-8.JEC. Where can you find what code version support what CCX Level? Is there a way to get this info off the AP?
Leo Laohoo Thu, 04/09/2009 - 17:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Try the command "sh dot11 associate all-client" and you should see the CCX version. For specific client the command is "sh dot11 associate ".
All Autonomous IOS (aIOS) and CAPWAP/LWAP IOS support CCX.
Cisco Compatible Extensions Program Q&A
http://www.cisco.com/web/partners/pr46/pr147/partners_pgm_qandas09186a0080154625.html
Robert.N.Barrett_2 Fri, 04/10/2009 - 05:47
  • Bronze, 100 points or more
Can you verify that I understand the nature of the problem:
- CCX 4 client sometimes is not able to associate to a given AP (but can associate some times)
- CCX 3 clients are always able to associate to the given AP
- CC4 client will associate to another AP when not able to associate to the first AP
If the above is true:
If the CCX 4 client can associate with the given AP at least some times, then you don't have a CCX issue. You could always test this temporarily by disabling CCX support (on the AP, or on the client). If you are using the PROSet client, this is easy to do within the wireless profile.
Since the CCX 4 can associate to another AP, then what is different between the APs? Code level? Settings?
What does the given AP show for the client status when the CCX 4 client is unable to associate?
Leo Laohoo Fri, 04/10/2009 - 19:54
  • Hall of Fame,
    2017 LAN, Wireless
Hi Robert,
I get what you mean.
This made we review the post and "At times the Client cannot authenticate even though there is signal" is odd.
When this happens and before you moved to another AP, how many clients are associated to this AP? >12 or more than >25?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
