ISDN PRI incoming Mobile Calls Fail
Apr 9th, 2009
Hello
We have a problem when Mobile calls to a Toil free number are rejected from Mobiles. Calls to same number from landline work ok. Our Service provider say that we are blocking the calls, but the our config hasn't changed and this has only started in the last week. I have done a Debug and the only difference I see is that the calling party number is not available. Can you have a look a this brief debug to tell me if its our Telco who is at fault.
<009><009>Exclusive, Channel 8
<009>Facility i = 0x9F8B0100A1080201010201008400
<009>Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
<009>Calling Party Number i = 0x21A3, N/A
<009><009>Plan:ISDN, Type:National
<009>Called Party Number i = 0xA1, '6046766161'
ISDN Se1/0:23 **ERROR**: accept_incoming_csm_call: modem problem Bearer capability not available(0x3A): b channel 7, call id 0x58EA
paolo bevilacqua Thu, 04/09/2009 - 07:35
  • Hall of Fame,
    Founding Member
The debug is incomplete. Please send a completeone without spurious fields if possible.
paolo bevilacqua Thu, 04/09/2009 - 07:53
  • Hall of Fame,
    Founding Member
Might be data trashing. Try reloading router.
infosateng Thu, 04/09/2009 - 07:55
We have already reloaded router, and we still get fast busy when we call from a Mobile.
paolo bevilacqua Thu, 04/09/2009 - 08:04
  • Hall of Fame,
    Founding Member
Please provide a trace for a call from a fixed line for comparison.
paolo bevilacqua Thu, 04/09/2009 - 08:28
  • Hall of Fame,
    Founding Member
There is no apparent reason why the router reject the call. Which IOS is thta ? Is it a modem call ? Do you have enough modems ?
infosateng Thu, 04/09/2009 - 08:31
The IOS is c3845-ipvoice-mz.123-14.T6.bin, and its not a modem call.
paolo bevilacqua Thu, 04/09/2009 - 19:28
  • Hall of Fame,
    Founding Member
Try 12.4(3j) that is known as the most stable. I cannot see a reason why the router is refusing the call.
