6509 Show Env
Answered Question
Apr 9th, 2009
Could you please post your comment about this output from show env.
Please focus on Power Supply 2 is that something wrong with that ?
power-supply 1:
power-supply 1 fan-fail: OK
power-supply 1 power-input: AC high
power-supply 1 power-output-fail: OK
power-supply 2:
power-supply 2 fan-fail: OK
power-supply 2 power-input: AC low
power-supply 2 power-output-fail: failed
By the way is there any documents which explains what is what in output of show env ?
Ersin
Correct Answer by Leo Laohoo about 8 years 2 months ago
Explaination:
power-supply 2 fan-fail: OK < --- Means that the extraction fan is functioning properly.
power-supply 2 power-input: AC low < --- Means that instead of receiving full power, it's only getting half power.
power-supply 2 power-output-fail: failed < --- Means that 1 of the 2 power cables are either connected or powered.
Overall Rating: 4.7 (3 ratings)
Leo Laohoo Thu, 04/09/2009 - 18:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Ersin,
How many power cables are connected to PS2? 1 out of 2? Provide 2 power "juice" to PS2 and this should fix your problem.
ergonullu Thu, 04/09/2009 - 22:05
Besides solution
I was trying to understand the output of the show env command.For example what do you see there as a error
Ersin
ergonullu Thu, 04/09/2009 - 22:17
Besides solution
Ersin
Correct Answer
Leo Laohoo Thu, 04/09/2009 - 23:24
  • Hall of Fame,
    2017 LAN, Wireless
Explaination:
ergonullu Thu, 04/09/2009 - 23:38
Thx for the answer
By the way do you know any documents which explains all show env arguments ?
Ersin
Leo Laohoo Fri, 04/10/2009 - 01:11
  • Hall of Fame,
    2017 LAN, Wireless
Hi Ersin,
Thanks for the ratings.
fly Tue, 02/21/2012 - 20:10
power-supply 1:
  power-supply 1 power-input: DC<<<<<<<<<<<<<<<<<<<<   how can we explain this we replace a ac power WS-CAC-4000W-INT
power-supply 2:
  power-supply 2 power-input: AC high
  power-supply 2 power-output-fail: OK
JS-access1#show power
system power redundancy mode = redundant
system power total =     3830.40 Watts (91.20 Amps @ 42V)
system power used =      2811.48 Watts (66.94 Amps @ 42V)
system power available = 1018.92 Watts (24.26 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3830.40 91.20  OK     OK     on
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      150.36  3.58  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Leo Laohoo Tue, 02/21/2012 - 20:32
  • Hall of Fame,
    2017 LAN, Wireless
Means that both of your power supplies are 4000 w and uses DC power input (instead of traditional AC).
fly Tue, 02/21/2012 - 20:46
But this power is AC power.  Why power input is DC
The other same model AC display AC input
Leo Laohoo Tue, 02/21/2012 - 22:16
  • Hall of Fame,
    2017 LAN, Wireless
Can you please post the output to the command "sh inventory | i 4000"
fly Wed, 02/22/2012 - 16:41
NAME: "PS 1 WS-CAC-4000W-INT", DESCR: "220v AC power supply, 4000 watt 1"
PID: WS-CAC-4000W-INT  , VID:    , SN: SON08131A4W
NAME: "PS 2 WS-CAC-4000W-INT", DESCR: "220v AC power supply, 4000 watt 2"
PID: WS-CAC-4000W-INT  , VID:    , SN: SNI0912BM5F
thankyou
Leo Laohoo Wed, 02/22/2012 - 17:01
  • Hall of Fame,
    2017 LAN, Wireless
Wierd.  Could be a bug.
fly Wed, 02/22/2012 - 17:50
it's really weird.
could be power problem
we install this power into other 6509 and 6513, it is also display " DC"
the software version should be different, i will check it.
it sems not affect switch running. but customer don't agree.
we will  find another power to test
thank you!
Jeremy
