Test logging smtp server on ASA
Answered Question
Apr 9th, 2009
  • Purple, 4500 points or more
Is there a way to test the smtp server from the ASA without having to wait for a problem to see if it works?
thanks,
John
Correct Answer by srue about 8 years 2 weeks ago
logging message level
...change a 'normal' logging message to a level that will trigger an smtp log message.
w/o seeing your current logging config, that's what i'd suggest. don't leave the message level changed for too long if it is a common log message, otherwise it will use up the resources in the ASA quickly. you can also use an ACL to control it further.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a2e04.shtml#use
Overall Rating: 5 (1 ratings)
Correct Answer
srue Thu, 04/09/2009 - 09:17
  • Blue, 1500 points or more
