WLC 4402 question
jrose3
We have a WLC 4402 and I want to know if I can reboot all my AP's without going to touch each one at each site? I see an option under the Wireless tab, click on an AP then I see "Perform a hardware reset on this AP" will this just simply reboot the AP or set it back to default?
runningboy01
Hardware Reset
(Button Reset AP Now)
Is that what you see? If so, that will only reset the AP itself, it will not put it back to default.
5 Replies 5
runningboy01
Hardware Reset
Thank you so much :)
So in simple terms this just reboots the AP?
Correct. It just reboots the AP.
Thank you. It would be great if Cisco corrected the language on this to just say reboot the AP as there is no need for this confusion.
