04-09-2009 11:42 AM - edited 03-06-2019 05:06 AM
I'd like to upgrade the IOS:
Mr_Bb#sh flash:
Directory of flash:/
0 ---- 49096 Nov 8 2000 04:37:53 +01:00 TinyROM-1.4(1)
66 -r-x 6229492 Mar 18 2008 04:29:07 +01:00 [c805-osy6-mw.123-26.bin]
8388608 bytes total (2031616 bytes free)
Mr_Bb#erase flash:
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erase of flash: complete
Mr_Bb#copy tftp: flash:
Address or name of remote host [192.168.2.8]?
Source filename [c805-osy6-mw.123-26.bin]?
Destination filename [c805-osy6-mw.123-26.bin]?
Accessing tftp://192.168.2.8/c805-osy6-mw.123-26.bin...
Loading c805-osy6-mw.123-26.bin from 192.168.2.8 (via Ethernet0): !
Build [dchih 26] -- Mon Mar 17 20:29:03 PDT 2008
File name: c805-osy6-mw
RAM size: 0x00d5b579 (14005625)
Raw size: 0x00ca05d9 (13239769)
Image size: 0x005f0df4 (6229492)
%Error writing flash:c805-osy6-mw.123-26.bin (Not enough space)
Mr_Bb#sh flash:
Mr_Bb#
Why can't I erase the flash?
TIA,
04-09-2009 06:35 PM
Try either the following:
1. delete /f /r flash:[c805-osy6-mw.123-26.bin]
Note: Is this even the right filename???
2. delete /f /r flash:c805-osy6-mw.123-26.bin
When either one is completed, see if you have the command "squeeze flash:".
If none of the commands work, the next command will COMPLETELY WIPE OUT your flash drive: format flash:
Hope this helps.
04-09-2009 10:50 PM
In the filename the problematic is the [] signs?
Yes, sh flash: shows the mentioned filename.
Your 1 and 2 options didn't do anything.
Can I use format flash: if this is the content of flash?
Mr_Bb#delete /f /r c805-osy6-mw.123-26.bin
Mr_Bb#sh flash:
So the question is: What will be with TinyROM-1.4(1)?
TIA,
04-09-2009 11:20 PM
The "format flash:" command will completely wipe out your flash.
04-09-2009 11:39 PM
Then what can I do with the TinyROM file?
The router is far from here ...
TIA,
04-09-2009 11:42 PM
Oh!
There isn't format command!
Mr_Bb#format ?
% Unrecognized command
Hmmm...
TIA,
04-10-2009 01:47 AM
1. You can copy TinyROM-1.4(1) to your TFTP server.
2. I can't believe "format flash:" is not supported on a 12.3 IOS when it's already present in the 12.2 IOS.
3. Try "squeeze flash:".
04-10-2009 02:12 AM
1. OK, I hope I can copy it. What will it be effected to the running router?
2. I copied the result what I got from the IOS for "format" command.
3. I'll make a try.
TIA,
04-10-2009 07:35 PM
I have no idea what the "TinyROM-1.4(1)" filename is for and I'm sure it has nothing to do with the operation of your router.
04-11-2009 08:13 AM
OK. We don't know what is TinyROM and it is needed or not. But what about erasing the flash:?
Squeeze flash:
Mr_Bb#squeeze flash:
All deleted files will be removed. Continue? [confirm]
Squeeze operation may take a while. Continue? [confirm]
Squeeze of flash complete
Mr_Bb#sh flash:
I think it is a little bit funny I can't remove the image.
TIA,
