04-09-2009 12:21 PM
I'm trying to implement Config Mgmt, but can not select the devices.
The error is:
CM0056 Config fetch failed for AGG_01 Cause: CM0204 Could not create DeviceContext for 2 Cause: CM0206 Could not get the config transport implementation for 172.29.147.5 Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
My Software version is LMS 3.0.1
CiscoWorks Common Services 3.1.1
Campus Manager 5.0.4
CiscoView 6.1.7
CiscoWorks Assistant 1.0.1
Device Fault Manager 3.0.4
Internetwork Performance Monitor 4.0.1
Integration Utility 1.7.1
LMS Portal 1.0.1
Resource Manager Essentials 4.1.1
Tanks.
Solved! Go to Solution.
04-09-2009 12:43 PM
Are you perhaps using ssh in one place (LMS or the device) and not on the other?
I take it you have installed the current RME Device package for the 7000 series routers (Resource Manager Essentials Device Package Version 7.2 for Cisco 7000 Series Routers, available at http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme). According to that package's readme, the 7606-S (sysObjextID 1.3.6.1.4.1.9.1.863) is supported as long as it is running a minimum IOS of 12.2 33 SRB2.
Hope this helps. Please rate this post if it does.
04-09-2009 12:37 PM
What is this device's sysObjectID?
04-09-2009 12:50 PM
sysObjetID is .1.3.6.1.4.1.9.1.863
04-09-2009 12:58 PM
As already stated, this device is supported in RME 4.1.1 provided you have the RME Rtr7000 package version 7.2. You can go to Common Services > Software Center > Device Update, and download and install all available RME and Common Services updates, and you should then be able to perform an Archive Sync to this 7600.
04-09-2009 12:43 PM
