Dennis Mink Thu, 04/09/2009 - 16:33
Yes this can be done:
-set up your queue on IPCC (resource, application, script etc.)
-in CUCM,create a ctI ROUTE point that points to that script.
-on the phones that are being called and you want to redirect to the queue, just set the call forward busy and CFWD no answer to point to the CTI route point.
good luck
Marwan ALshawi Fri, 04/10/2009 - 03:47
in addition to the nice post above
i would suggest to creat the CTI from the CRS admin which is recommended by cisco to avoid any issues with ports and so on
and from the question i think there is know CSQ at all
make sure to configure the steps mentioned above and you have agents associated with your CSQ to get the call answered
