Rob Huffman Fri, 04/10/2009 - 07:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Jeff,
To request the free Cisco WCS Demonstration License, visit
http://www.cisco.com/go/license or
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet.
A free 30 day, full featured evaluation copy of WCS for 10 AP support can be downloaded on Cisco.com. Please note that you will be prompted to enter your contact information and the hostname of the WCS server you would like to install the license on so plan on having that information in front of you prior to the download. The download will then generate a license file that you will be emailed. Following are the instructions to download 30 day WCS evaluation software :
1). https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet.
2). Navigate to Network Mgmt Products
3). Look for Wireless Control System
** The WCS Demo Software is NOT supported by the Cisco Technical Assistance Center.
From this good doc;
http://www.cisco.com/en/US/products/ps6305/products_data_sheet0900aecd804b4646.html
Hope this helps!
Rob
jwrightsman1 Fri, 04/10/2009 - 08:20
Hi Rob,
Thanks for the reply. This link does not work plus when I did finally naviagate to the download page it did not have the demo software for WCS. When I tried to download the WCS they did have it said I needed authorization.
Jeff
Rob Huffman Fri, 04/10/2009 - 10:39
  • Hall of Fame,
    Founding Member
Hi Jeff,
Sorry about that :)
Installing Software
You can download software during the ordering process.
PLEASE FOLLOW THESES STEPS TO DOWNLOAD AND INSTALL SOFTWARE
1. Go to http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=279705270 and log in.
2. Click on the appropriate link in the table
From this excellent WCS doc;
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd804b4646.html
Hope this helps!
Rob
