CVP + ICM Abandonded Call Disposition
Apr 9th, 2009
  • Silver, 250 points or more
All,
We are trying to identify Calls that have been abandonded in Queue, which is Call Disposition 2 according to the guide.
However I ran a query and can see that there hasn't been a single one (even though we have tested)
The abandoned calls ALWAYS get code 13..
I see in the admin guide on this forum there is a portion of the CVP admin guide that states that required calls are not correctly reported, but should it really say that any skill group that has requery enabled won't report correctly?
Also we are using a very large custom Java application through CVP upfront before dropping it off to queue's.... do you think this has something to do with it?
Chad
Overall Rating: 5 (1 ratings)
Chad Stachowicz Fri, 04/10/2009 - 12:38
No love huh? Can anyone wiht a ICM 7.2x and CVP in comprehensive flow, do a few queries and see if they have any call's with call disposition 2? Trying to figure out if its a bug with CVP and ICM. I checked all 3 of my installs and they are all screwed on this topic =/
Thanks!
Chad
david.macias Fri, 04/10/2009 - 17:45
  • Blue, 1500 points or more
Chad,
Checked my current project and nope, no CD of 2. I'll do some digging around and see if I find anything.
david
Chad Stachowicz Mon, 04/13/2009 - 08:49
David,
Thanks for checking.
Geoff, Dignan, Deren
Can you guys check one or 2 of your CVP projects and see if you get any CD of 2? If not, I think I am going to open a bug ticket. Would also be nice to check ICM 7.5 is someone has one..
Chad
Chad,
What are you talking about? Are you talking about Termination Call Detail: Call Disposition?
2 = Abandoned in Local Queue
In ICM, indicates the call was abandoned in the ACD queue while queued to an ACDanswering resources (for instance, a skill group, voice port, trunk, etc.)
Does not apply to IPCC Enterprise.
Geoff
Chad Stachowicz Mon, 04/13/2009 - 20:42
Geoff,
I am. The problem is we are having problem distiguising, abandoned call in queu vs Calls that were ended in our Self Service app. Maybe you know this answer? I though the way was to look for CD = 2.
Thanks, the help is appreciated!
Chad
Chad,
it appears from that document that CD = 2 would not be used for IPCC/CVP.
The only reliable way I know to count the ones that hang up in your CVP VXML Self Service application is by using the activity log.
I upload them into SQL Server using the supplied Audium importer and query the data with SQL commands; but a simple "grep | wc -l" on the activity log file works amazingly well. ;-) Just install the cygnus tools and you are off to the races.
If you have the Reporting Server hooked up, you could go that way. That's a big hammer for a little nut.
Geoff
david.macias Tue, 04/14/2009 - 07:01
Chad,
How about looking at the RCD table for a target type = 14?
david
Br3ndaMca Thu, 11/07/2013 - 05:06
Hi Chad
Did you ever find the solution to this?  I'm getting something similar in 8.5.4 but its for calls abandoning in queue (abandon ring is fine) I'm not getting the tcd row showing the skill and route at all, just the CVP leg but again with call disposition of 13.  In RCD I can see the correct Route ID and RouterErrorCode 448 identifying the call as abandoned.
I have a TAC case open on it but don't seem to be getting anywhere with it.
Brenda
