Compression on Internet Link
Apr 9th, 2009
Hi All,
I have Internet link and I want whether can we configure any compression on that so that I can use it more effectively. If it can then when for de-compression we need to configure something at the receving end.
Please help. Thanks in Advance
Giuseppe Larosa Fri, 04/10/2009 - 04:09
  • Hall of Fame,
    Founding Member
Hello Suresh,
any type of compression requires the involvment of both ends of the link.
Other options you should investigate include:
the usage of Web Caches
a QoS implementation to provide better treatment for important traffic
and also a link upgrade (more bandwidth)
Hope to help
Giuseppe
