Disabling FAC
Apr 9th, 2009
For CME, is it possible to disable FAC
for analog telephones.
The problem occurs when analog telephone users press *#... combinations by mistake.
After telephone cannot be used
THANKS
donovan222 Fri, 04/10/2009 - 06:07
You can setup a different CSS for your analog phones and point them to a different route pattern that doesn't have Require Forced Authorization Code check.
