FWSM
ciscorajeev
hi,
what is command to check the image in fwsm?
Rajeev
7 Replies 7
t-yamashita
Level 7
Level 7
Hi Rajeev
I think you can confirm it in "show module" on MSFC. or "show version" on FWSM.
Tomoyuki
Thanks for our reply
But it does not show the complete file and its size. If i have to verify is the downloded size is correct, how can i do it
I would like to suggest you login to FWSM by "session slot processor 1".
And may well be able to confirm in something like "show flash" on the FWSM.
Tomoyuki
Hi I am tring to upgrade the FWSM image but while pinging to switch i am getting packet drops...What may be the reason.
just attached logs of FWSM.
FWSM# ping 172.23.88.250
Sending 5, 100-byte ICMP Echos to 172.23.88.250, timeout is 2 seconds:
Success rate is 40 percent (2/5), round-trip min/avg/max = 1/1/1 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
Success rate is 20 percent (1/5), round-trip min/avg/max = 1/1/1 ms
FWSM#
That may be due to physical errors.
You can ping the same address from the Switch directelly ?
Omar
nop here also i was getting error..
I was able to ping switch, fw also but with packet drop. i also tried from switch and same response
If you arrive to ping the FWSM that means that it's running the OS and getting the IP.
Can you please send the output of the command #show tech-support of the CAT 6500 ?
Omar
