Wan Interface card doesnt get recognised
Answered Question
Apr 10th, 2009
I bought a new WIC, 2MFT-t1-D1 however it doesnt get recognised. Router is 3640, It has Ethernet module which works fine.
Here is the config;
FramedRelay>en
Password:
FramedRelay#show diag
Slot 1:
Unknown (type 204) Port adapter
Port adapter is disabled
Port adapter insertion time unknow
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAD062709Q3
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-HDV=
EEPROM format version 4
EEPROM contents (hex
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 44 30
0x20: 36 32 37 30 39 51 33 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 2:
Combo 1E, 2W Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
Hardware revision 1.2 Board revision C0
Serial number 14671223 Part number 800-01789-05
FRU Part Number: NM-1E2W=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 37 01 02 00 DF DD 77 50 06 FD 05 00 00 00 00
0x10: 60 00 00 00 99 07 07 17 FF FF FF FF FF FF FF FF
FramedRelay#
FramedRelay#show version
IOS (tm) 3600 Software (C3640-I-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 16:41 by dchih
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
FramedRelay uptime is 5 minutes
System image file is "flash:c3640-i-mz.123-26.bin"
cisco 3640 (R4700) processor (revision 0x00) with 125952K/5120K bytes of memory.
Processor board ID 26611141
R4700 CPU at 100MHz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
FramedRelay#
Correct Answer by Edison Ortiz about 8 years 1 month ago
You have a NM-HDV= and per its documentation, you need IP Plus
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a00800b65d6.shtml
HTH,
__
Edison.
Correct Answer by Leo Laohoo about 8 years 1 month ago
I think you need IOS Plus feature sets.
Overall Rating: 4 (2 ratings)
Correct Answer
Leo Laohoo Fri, 04/10/2009 - 01:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
framedrelay Fri, 04/10/2009 - 01:15
how can I be sure whether it has something to do with IOS? or the hardware itself is faulty? Is there anyway to check that?
IOS plus feature? wat is that? Kindly explain.
Sylvester
framedrelay Fri, 04/10/2009 - 01:36
I've another 2621 with the same Module, same problem. In 2621 atleast I see LED (green) on module (WIC) when the router boots up..
IOS (tm) C2600 Software (C2600-I-M), Version 12.0(3)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 15-Apr-99 15:41 by kpma
Image text-base: 0x80008088, data-base: 0x80693A88
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
FramedRelay2621 uptime is 2 minutes
System restarted by power-on
System image file is "flash:c2600-i-mz.120-3.T3"
cisco 2621 (MPC860) processor (revision 0x101) with 18432K/6144K bytes of memory
Processor board ID JAB033106PB (59986668)
M860 processor: part number 0, mask 49
Bridging software.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
FramedRelay2621#
Kindly help.
Leo Laohoo Fri, 04/10/2009 - 01:48
  • Hall of Fame,
    2017 LAN, Wireless
HI Sylvester,
Have you tried moving the modules back and forth the 2621 and the 3640?
framedrelay Fri, 04/10/2009 - 05:55
Thanks for your reply.
yes, I tried that. I took the module from 3640 (on 3640 LED didnt blink) & placed it on 2621 (the card that was on 2621, LED works).
Once the module is on 2621, the LED works.
The one which was on 2621 - which was moved to 3640 - LED didnt work..
So in short, which ever module that goes on 3640, LED doesnt work.
Kindly help.
Cheers,
Sylvester
Leo Laohoo Fri, 04/10/2009 - 19:37
  • Hall of Fame,
    2017 LAN, Wireless
Thanks Edison.
Leo Laohoo Sun, 04/12/2009 - 00:00
  • Hall of Fame,
    2017 LAN, Wireless
Do you have a CCO account?
framedrelay Sun, 04/12/2009 - 08:30
Hi :)
No, I dont have a CCO account & I don't work with cisco equipments as well.. I work on HiQs (Siemens Call agent) :)
Its because I am interested in Cisco networks I had set up a lab @ home with 5-6 routers and call manager + few phones, done my CCNP and CCVP..
I realized one thing very lately, I need a CCO login for each and everything .. my phones/ATAs need a SIP image, my routers/switches IOS version are outdated :(
Are there any other sites? or ways to get these softwares? Just curious..
Thanks for your help. Much appreciated.
Sylvester.
Edison Ortiz Sun, 04/12/2009 - 08:33
  • Hall of Fame,
    Founding Member
No, you need a SmartNet contract associated to your CCO account in order to be able to download IOS images from Cisco.
You won't find on this site any suggestion on how to illegally download software from other sites.
__
Edison.
Leo Laohoo Sun, 04/12/2009 - 16:37
  • Hall of Fame,
    2017 LAN, Wireless
"Are there any other sites?" < --- It's like being invited to someone's lavish party and you're (thinking of) stealing the silverware.
Can you talk with the network team of your office? I would not be surprise if they will provide assistance to you. If you have that self-motivation to learn, they should invest in you some how.
framedrelay Sun, 04/12/2009 - 19:12
Never mind, I will get it from Cisco itself.
Thanks for the help, Much appreciated.
Thanks & god bless,
Sylvester.
framedrelay Sat, 04/18/2009 - 07:14
Issue is resolved. Upgraded to c3640-js-mz.124-23 :)
Thanks for the help. Much appreicated.
Sylvester
