Number not available
Apr 10th, 2009
I have a CCM 3.3
Two 7905 IP phones registred in the same partition.
And if I try to call from one to another it shows the error message : 'number not available'
What can be the problem due of ?
Regrads,
Omar
Chris Deren Fri, 04/10/2009 - 06:00
Having the phones in the same partition is not sufficient, you need to ensure that the partition is listed in the calling search space applied to the phone as well.
HTH,
Chris
omar.elmohri Fri, 04/10/2009 - 22:50
Chris,
It's also within the CSS.
And I mention also that I can call from one to the second and not in the inverse sense.
Omar
