CW LMS 3.0: Device Discovery doesn't stop/work
Apr 10th, 2009
Hi everybody,
we are using an 90-days evaluation version of LMS 3.0 as NMS in a temporary customer-network:
- 70 Switches
- cdp enable
- seed-devices are the core-switches
- ip-range is limited to the /24 mgmt-vlan
- "use default credentials" is enabled.
When I start Device Discovery in CS, the job runs eternally without finding new devices. Adding devices manually works.
Any ideas?
Rolf
Joe Clarke Fri, 04/10/2009 - 08:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of Campus Manager and Common Services do you have?
Rolf Fischer Fri, 04/10/2009 - 10:25
OS ist Windows 2003
Campus Manager: 5.0.4
Common Services: 3.1.1
Joe Clarke Fri, 04/10/2009 - 10:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post the CSDiscovery.log and NMSROOT/conf/csdiscovery/CSDiscovery-config.xml.
Rolf Fischer Mon, 04/13/2009 - 02:57
Strange: CSDiscovery.log has not been changed since 27.03.09.
Running Wireshark showed that nothing happens at all when I start Device Discovery.
Rolf Fischer Sat, 04/18/2009 - 01:11
After enabling debugging for Device Discovery the CSDiscovery.log contains now a lot of entries like the following:
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryUtil : getNMSROOT] : NMSROOT: d:\PROGRA~1\CSCOpx
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryJobUtil : processStatus] : [processStatus] Called!!
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryJobUtil : processStatus] : Executing jobCmd: d:\PROGRA~1\CSCOpx\bin\pdshow.cmd CSDiscovery
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryJobUtil : processStatus] : ErrorStream Line: ERROR: CSDiscovery is not a registered server name.Please enter a valid process/server name or check the case of the entered process/server name.
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryJobUtil : processStatus] : Job Command Response:
[ Sa Apr 18 09:01:53 GMT 2009 ] DEBUG [DiscoveryJobUtil : processStatus] : Exit
I don't understand the statement "CSDiscovery is not a registered server name" - what exactly do I have to do to "register CSDiscovery"?
