Can a single CUCM cluster use two Unity's on different AD's?
Answered Question
Apr 10th, 2009
I am supporting 2 different companies with a single CUCM 6.x cluster. Each are setup on different partitions and CSS's.
These companies are on the same IP network, but have different Active Directories.
We have 1 Unity server setup right now for company A on their Exchange server.
Company B would like to use Unity as well, but from what I understand, we cannot use company A's Unity because of the AD integration.
So we are considering buying a second Unity server and having it integrated with Company B's AD. The only thing I am not sure of is, does CUCM 6.x support 2 different Unity servers on seperate AD's?
Correct Answer by Chris Deren about 8 years 2 weeks ago
Absolutely, CM integration to Unity is AD independent.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Fri, 04/10/2009 - 05:58
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
btrotter Fri, 04/10/2009 - 07:21
Good, someone told me that they thought you could only have 1 Unity implementation per CUCM installation.
Thank you,
Brian
Chris Deren Fri, 04/10/2009 - 07:25
  • Hall of Fame,
Not at all, you can have multiple switch integrations.
HTH, please rate all helpful posts!
Chris
