ACE - Http to https redirect
Apr 10th, 2009
Hello All
Here is the config:
access-list any line 8 extended permit icmp any any
access-list any line 16 extended permit ip any any
probe http web
request method get url /index.html
expect status 200 200
parameter-map type ssl tesstC
cipher RSA_WITH_AES_128_CBC_SHA
rserver redirect REDIRECT-HTTPS
webhost-redirection https://%h%p
inservice
rserver host web1
ip address 192.168.0.2
inservice
ssl-proxy service testC
key ca.key
cert ca.crt
ssl advanced-options tesstC
serverfarm redirect farm-https
rserver REDIRECT-HTTPS
inservice
serverfarm host webfarm
probe web
rserver web1 80
inservice
class-map match-all CLASS-REDIRECT
2 match virtual-address 10.1.1.1 tcp eq www
class-map type http loadbalance match-all L7web
2 match http header Host header-value "dummy-host\.example\.com"
class-map type http loadbalance match-all L7web2
2 match http header Host header-value "dummy-host2\.example\.com"
class-map match-all web
2 match virtual-address 10.1.1.1 tcp eq https
class-map match-all web2
policy-map type loadbalance http first-match POLICY-REDIRECT
match test http url /*
class class-default
serverfarm farm-https
policy-map type loadbalance http first-match webl7policy
class L7web
serverfarm webfarm
policy-map type loadbalance http first-match webl7policy2
class L7web2
serverfarm webfarm
policy-map multi-match VIPs
class web
loadbalance vip inservice
loadbalance policy webl7policy
loadbalance vip icmp-reply active
loadbalance vip advertise active
ssl-proxy server testC
class web2
loadbalance policy webl7policy2
class CLASS-REDIRECT
loadbalance policy POLICY-REDIRECT
It seems the ACE is not capable of handling the response on port 80 and the redirection from 80 to 443 even if the url requested is different.
Connections to host-dummy2 shouldn't be redirected and should be served on port 80.
Overall Rating: 5 (1 ratings)
dario.didio Fri, 04/10/2009 - 06:48
  • Silver, 250 points or more
you will never reach the class CLASS-REDIRECT because you will have a match on web2. They both match on 10.1.1.1:80.
What are you exactly trying to accomplish?
If I'm correct:
Traffic to 10.1.1.1:443 will be balanced over serverfarm webfarm and decrypted if the HOST header-value contains dummy-host.example.com. What should be done if the VIP matches but the header doesn't?
Traffic to 10.1.1.1:80 will be balanced over serverfarm webfarm if the HOST header-value contains dummy-host2.example.com. What should be done if the VIP matches but the header doesn't?
Traffic to 10.1.1.1:80 will be redirected to 10.1.1.1:443.
Is this correct?
Mehdi_ab Fri, 04/10/2009 - 10:23
Hello
There should be a match on "web2" only if Host header-value contains dummy-host2.example.com else traffic will reach CLASS-REDIRECT.
So if you target http://dummy-host.example.com, you will be redirected to https://dummy-host.example.com. Working.
If you target https://dummy-host.example.com, then you will reach the right serverfarm. Same as the one above. Working.
If you target http://dummy-host2.example.com, you should reach the serverfarm and NOT be redirected to https://dummy-host2.example.com... which is happening right now. Not working
dario.didio Mon, 04/13/2009 - 23:38
If you want that to happen, I would do it like this:
create a single policy-map for 10.1.1.1:80 and:
- when your URL contains dummy-host2.example.com, loadbalance over the serverfarm, ELSE, redirect it.
class L7web2
serverfarm webfarm
class class-default
The class-default catches everything the more specific class maps in before it don't match.
HTH,
Dario
