Warning message
VWIC-2MFT-T1 Voice and Data?
Apr 10th, 2009
I have a 2821 with a VWIC-2MFT-T1 running a PRI. I would like to plug a T1 into the second port on this card am curious if this is possible. I've read and heard that with the single clock on these older cards, there could be issues... Can you confirm or deny...have you done this successfully?
Overall Rating: 5 (1 ratings)
Edison Ortiz Fri, 04/10/2009 - 06:53
  • Hall of Fame,
    Founding Member
Yes, you can use the second port for data.
Per its documentation:
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
• Mixed data and packet voice---The Cisco MFT VWIC2 interface cards can simultaneously support both data and voice, reducing the complexity and number of network components and facilitating a graceful migration to bandwidth-efficient packet voice.
__
Edison.
kardos420 Fri, 04/10/2009 - 07:01
This much I know...That is the VWIC2. This card is a VWIC. The next generation fixed the clocking issue.
paolo bevilacqua Fri, 04/10/2009 - 07:36
  • Hall of Fame,
    Founding Member
You may or may not have issue, this depends if the second circuit is off the same master clock. In theory, all circuits in a same country or provider should be, then practice may be different.
jwinters99 Fri, 09/25/2009 - 04:32
Great info to know. The next question is will that work in a UC520? I have a UC520 that has a PRI now and they want to terminate another T1 in it. I cannot find anywhere that says that platform will support a 2MFT-T1. Any ideas on that?
jwinters99 Fri, 09/25/2009 - 04:41
Thanks for the info. Very helpful. Exactly what I needed to know, but not what I wanted to hear...
paolo bevilacqua Fri, 09/25/2009 - 04:45
  • Hall of Fame,
    Founding Member
Cisco wants you to use a true WAN router in front of what really is only a PBX.
Or convert to a 28xx and do everything with one box.
Thank you for the nice rating and good luck.
