Vlan clarification
Apr 10th, 2009
Dear sir,
I have cisco3750 l3 switch and remote i have unmanagble switch.Now i want to creat 3 vlans and that three vlans shouls accesesble to one of the trunk port and i want to know from which vlan traffic is going.
In this setup remote side compalsary l2 switch is require or not.If unmanagble switch is there set up is possible or not.
Plz give me any config examples.
If any body reply this iam very greatfull to him.
srini
Giuseppe Larosa Fri, 04/10/2009 - 07:49
  • Hall of Fame,
    Founding Member
Hello Srini,
if the unmanageable switch is on the path this is a problem: you cannot know if it lets the 802.1Q vlan tagged frames to go through it or not and you cannot configure it.
If it is a leaf not in the main data path you can think to configure the link for carrying three vlans.
you need to make the single physical link a L2 trunk to carry 802.1Q tagged frames.
The L3 switch can provide L3 services using logical SVI interfaces.
example:
L3switch
! create the l2 vlans
conf t
vlan 10
name vlan10
vlan 20
name vlan20
vlan 30
name vlan30
! configure the trunk port
int gi1/0/12
switchport
switchport trunk enc dot1q
switchport mode trunk
switchport trunk allowed vlan 10,20,30
no shut
! create the L3 logical SVI
int vlan 10
ip address 10.10.10.1 255.255.255.0
no shut
int vlan 20
ip address 10.10.20.1 255.255.255.0
no shut
int vlan 30
ip address 10.10.30.1 255.255.255.0
no shut
a manageable L2 switch can be configured to support the 3 vlans and with a trunk configuration on the link towards the L3switch.
Hope to help
Giuseppe
lamav Fri, 04/10/2009 - 07:51
  • Blue, 1500 points or more
Hello Srini:
This is what I understand from what you are telling us:
You have a 3750 L2 switch that you would like to create 3 VLANs on and have them send traffic through a trunk to an unmanaged switch.
Correct?
If so, I imagine that the unmanagable switch does not allow you to create vlans and segment your LAN. Just taking a guess, it probably places all ports in one pre-configured, untagged vlan.
I would venture to say that if you wanted to connect a Cisco switch to such a fixed configuration switch like the one you have, you would probably have to place all the ports in one vlan and send it on a dotiq trunk on vlan 1, which is also untagged.
Again, I am just taking an educated guess...
So, to answer your question regarding 3 vlans, I would say no. You would have to be able to configure your unmanaged switch with the 3 vlans and allow them on a dot1q trunk.
Maybe someone else has another perspective or experience doing what you want.
Victor
lamav Fri, 04/10/2009 - 07:53
Giuseppe:
Good afternoon, buddy:
Sorry for the cross post.
Victor
Giuseppe Larosa Fri, 04/10/2009 - 08:19
  • Hall of Fame,
    Founding Member
Hello Victor,
Good Easter !!
Best Regards
Giuseppe
