04-10-2009 07:37 AM - edited 03-06-2019 05:07 AM
3750 switch
No boot statement in the config
Configuration register is 0xF
Which IOS do you think this switch will load when it boots?
Directory of flash:/
2 -rwx 4104162 Mar 1 1993 00:03:30 +00:00 c3750-i9-mz.122-20.SE1.bin
3 -rwx 616 Mar 1 1993 00:00:34 +00:00 vlan.dat
5 -rwx 8361 Jan 18 2009 08:29:20 +00:00 config.text
6 drwx 128 Jul 13 2007 15:47:03 +01:00 c3750-ipbasek9-mz.122-37.SE
9 -rwx 1934 Jan 18 2009 08:29:20 +00:00 private-config.text
10 -rwx 9578 Nov 22 2008 03:33:50 +00:00 backup-112108
11 -rwx 1048 Jan 18 2009 08:29:20 +00:00 multiple-fs
04-10-2009 07:51 AM
Hello Tom,
it should load the image with the lowest file index in flash
note: a config register of 0xF is normal for this switch
Hope to help
Giuseppe
04-10-2009 07:55 AM
"it should load the image with the lowest file index in flash"
Tom, Giuseppe is correct and just to add one small thing: this is what they mean when you read in Cisco literature that the "first available IOS" in Flash will be loaded.
Victor
04-10-2009 05:04 PM
Do a "show boot" and it should tell you . If its loaded with the image in the "directory" it will have a boot statement and it would have been put there using the archive command which autmatically puts the boot variable in.
04-10-2009 06:36 PM
3750 is a fixed configuration switch for which you won't be able to change it's config-register. Moreover, 0xF will load the first IOS in the flash:; which means "c3750-i9-mz.122-20.SE1.bin " in your case.
I am guessing you are getting confused with "drwx 128 Jul 13 2007 15:47:03 +01:00 c3750-ipbasek9-mz.122-37.SE". This is the directory that 3750 creates which can be noticed with "d" infront of that file.
I hope this will help you.
04-10-2009 07:21 PM
Without a boot statement, I think it will load c3750-i9-mz.122-20.SE1.bin, being that it is the first on the list.
