CUCM 6.1 -- Is there a way to disable services via CLI?
Apr 10th, 2009
I've had this problem for some time now -- the Cisco Messaging Interface service keeps dying and flooding my RTMT logs with CriticalServiceDown messages. I don't use the service (from what I have read it is used to connect to 3rd party voicemail systems and I don't use any 3rd party voicemail systems). I have tried to disable the service via the web interface, but it always fails with a general database error.
Is there a way to disable the service via CLI so I can stop the flooding of my logs with bogus messages?
Jaime Valencia Fri, 04/10/2009 - 15:44
you can only stop, start or restart services from the CLI.
if this helps, please rate
lc.santos Fri, 05/22/2009 - 05:09
This command return this message:
Invalid service name for start/stop, valid names are:
System SSH
Cluster Manager
Service Manager
A Cisco DB
Cisco Tomcat
Cisco Database Layer Monitor
Cisco CallManager Serviceability
I still have the same issue. Any help?
nesharm2 Fri, 05/22/2009 - 05:20
you can first try command
"utils service list"
This will give you the list of services and their status
Then you can give the command
"utils service stop "
remember the service name has to exactly the same. Best bet is to copy service name and give the command
htluo Fri, 05/22/2009 - 05:28
You should do it from "Cisco Unified Serviceabilty" web page.
Go to Tools > Service Activation. Deactivate "Cisco Messaging Interface" service.
