What Image for OSPF on my 3560?
Apr 10th, 2009
I'm trying to run OSPF but when I try to configure it, this is what happens:
ALLEN-1.11.5-CoreSW(config)#router ospf 1
It has the IP BASE image. Do I need IP Services?
Here is a sh version:
ALLEN-1.11.5-CoreSW#sh ver
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEB4, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 14:19 by yenanh
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
ALLEN-1.11.5-CoreSW uptime is 3 days, 3 hours, 32 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEB4/c3560-ipbase-mz.122-25.S
EB4.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1034ZHLB
Last reset from power-on
4 Virtual Ethernet interfaces
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:2F:B3:F2:80
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT10335QW4
Power supply serial number : AZS103003HV
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1034ZHLB
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEB4 C3560-IPBASE-M
Configuration register is 0xF
Edison Ortiz Fri, 04/10/2009 - 08:46
  • Hall of Fame,
    Founding Member
Yes.
__
Edison.
