Quick Question about PIX
Apr 10th, 2009
Hello All:
I have no experience on PIX firewalls and am considering buying an older one on Ebay to work/train on and use in a lab environment. Can someone point to a model number that would be worth looking into? Someone suggested a PIX 515E?
Any advice would be appreciated.
JS
Jon Marshall Fri, 04/10/2009 - 08:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
JS
PIX 515E would be a good choice. Don't go for a Pix 501 or 506E as they cannot run anything later than version 6.x code.
If you want to run 7.x on a Pix you will need 128Mb of memory in it. You could always buy a PIx515E running 6.3 code and then add memory later.
Jon
