cwcli out put LMS 2.6
eliaspaulos
I have difficulty some times on my script to sorted out the cwcli output because each column separated by "space". either any way, the out put column separate by "comma" easily to identify columns?
Thanks.
The ut -cli output is also delimited by commas by default.
6 Replies 6
Joe Clarke
Exactly what command are you running?
cwcli invreport -u XXX -p XXX -reportname "XXX" -device %
from script also using
opt/CSCOpx/campus/bin/ut -u XXXX -p XXXXX -cli -query all -layout XXXXX
The inventory reports are delimited by commas already.
I am sorru I think sent you the wrong one, the one for user tracking.
thanks J. you are right. there is some script on my system actually convert the csv output from CW to text.that confused me. thank you for confirmation.
